- Nov 8, 2023
- Kalispell, Montana
- Larry
- C10
- 250 6 cylinder
It went well and quickly. Disconnect coolant hoses. Take out the glove box and ash tray assemblies, removed the 3 control cables, one screw to the defroster Y pipe, and one 10mm head screw on the far-right interior firewall. Burned off the paint and coating from the three 1/4" studs that protrude thru the firewall near the fan motor.
and the heater box actually fell out on its own.
It's dusty and dirty but I did expect more debris inside, not too much:
And here is the weeper, on the return tank end. Nothing obvious why it started, but it was wet in that area:
Heater core is held in place by a round retainer bar near the hose connections, and a flat rectangular retainer bar on the return tank end.
Mine were rusty and dirty, but cleaned up ok:
Since these steel pieces are in direct contact with the brass heater core, I plan to wrap them with rubber tape or put heat shink on them to prevent the dissimilar metals from direct contact.
