Remove or trash?
Schlagger
New Mexico
Will
C30
Replacing my whole exhaust, and when i was removing the Y pipe a bolt broke in half. Its the bolt on the drivers side closest to the engine. Should I try to get that thing out or just replace the manifold?
436'd skylark
VT
Joe
2500HD
Durajunk
It'll drill easy enough. Lace up your boots and fix it
Schlagger
New Mexico
Will
C30
At least you didnt tell me to put my big girl panties on. Any tips other than PBlaster?
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welding a nut onto the studs is another way to get them out. some 6011 or 7018 blasted into it should do it.
Schlagger
New Mexico
Will
C30
I dont really have anything to work with. It broke a few threads deep into the manifold.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
You could try one of the screw/bolt extractors, but i've never had a whole lot of luck with those. If you do try, use lots of pb blaster and heat it up with a torch to help loosen up the threads.
You can also just drill it out with a bit just undersized for the threads (go off of the bolt's shank diameter) then chase them with a tap.
There's more than enough meat in those flanges that you can drill all 3 of them out and then increase the thread size so you have all matching bolts on that manifold.
ben_swager
