Rebuilding my A/C system
robertjhaley
Robert
c1500
I have an '86 GMC truck that originally had A/C. Many parts were missing when I bought it. The fan blows but I can't switch between the different vents because the vacuum lines were disconnected when a different motor was installed. Does anyone know where I can find diagrams or information that can assist me in getting the vacuum set back up? I installed a Jegs vacuum reserve canister to assist with the brake booster. The motor has an aggressive cam so I don't get a lot of idle vacuum. Does anyone know how much vacuum it takes to run the A/C duct work?
I think any amount of vacuum will work - the system might just react slower at lower vacuum. Just make sure you tap into the intake manifold under the throttle plates (i.e. an unported connection)
robertjhaley
Robert
c1500
Thanks for the info! This is exactly what I needed.
malanr
