Irishman999
- Jul 30, 2010
- Safford Arizona
- Jason
- K-1500 High Sierra
Almost done here, just thought I would post a breakdown of everything.
I started with a 93 5.7 block complete I got on craigslist for 150 bucks. #5 cylinder was trashed so I had to either bore it .30 over and pay for a sleeve or go .60 over and possible have to get a sleeve anyways if it did not clean up. Crank needed to be turned, never even got into the heads before I traded it for another engine.
Core engine: 150, pulled myself.
Block machine work: 480
Pistons: 100
Rods: +/- 300
Crank work: 200
Cam bearings installed: 80
Heads rebuilt: +/- 300
Gaskets/rings/bearings/freeze plug kit: 200
Thats as far as I got with my small block and you can see its already over 1,800 bucks. I never got to the assembly, that was just machine work and stuff I ordered. Some stuff was not included like pressing pistons into rods and having the rotating assembly balanced. Once again the aftermarket idea in your head kicks in and you worry about fastener strength and your investment coming apart so you are ordering arp fasteners, that will take you WAAAAAY over what a crate motor costs. Alot of things are left out like the oil pump, timing chain and lifter assembly.
The engine rebuild kit price is very cheap, I spent 200 bucks on gaskets alone. I go strictly with Fel-pro gaskets so it costs more, I also strictly use clevite 77 tri metal bearings. I also use total seal piston rings, last set I got for the small block was a couple hundred bucks. You dont HAVE to spend the extra on the premium stuff but its just a good idea to protect your investment. Same goes for the rods, I could have re used them but you have to understand those rods have been spinning around for the past 20 years, why take the risk re using rods?
Thats my personal experience, I never assembled the small block. I just ordered parts and got the block fixed up. I could have had a crate motor at that point and be done with it. Beauty of building your own and why I do it is you can drag out the process over several pay checks and end up with premium parts in the end. You spend a shitload more than a crate motor but its not all at once. Thats why you cant go wrong getting a core motor to work on while you drive the truck.
Pistons: 100
Rods: +/- 300
Crank work: 200
