joe green
- Apr 1, 2013
- NY
- Joe
- k20
Hello, I have a 78 k20 that needs all the rear spring hangers, and basically all the cross members from the transfer case back not including the transfer case cross member. I started looking for frames to purchase that i can pull the parts off that i need. One frame i found for sale is a 2wd 85 c10 frame. I know that the front suspension between the c and k are completely different but what about the rear. Is everything the same between the c and k from basically the transfer case back? What about year differences? Will an 85 frame be the same as a 78 for the rear suspension and cross members. I know to look only for 10 or 20 series frames as they are the same and the 30 series is different.
