Rear-end shot
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Let's just say this is all that's left!!
Looks like GovBomb... I Thought that piece sticking through the cover was too odd shaped to be a spider gear or chunk of the pinion.
FYI: Try to put your bearing caps back on what side they came from and in the same orientation as they were removed. If you've already forgot closely inspect them for a witness mark to get them back where they go. If it's been apart before there's a good chance someone marked the caps and housing before disassembly.
Low Summit racing estimate for new parts $850 not including a cover or labor.
https://www.summitracing.com/parts/sum-730966/make/chevrolet/model/k10/year/1980
https://www.summitracing.com/parts/svl-2023695/make/chevrolet/model/blazer/year/1988
https://www.summitracing.com/parts/mgr-r10rmk/make/chevrolet/model/blazer/year/1988
CalSgt
CA
Casey
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Put in new spiders and go. Not a bad job.
Carb'ed Vortec 350
I think @rusted nuts meant get new axle and go. He may not have looked at the carnage pics
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
No I meant get new spider gears and go There was a post on here a week or 2 ago telling how to remove the retaining bolt. Once that bolt is out it is only a 45 min job to change spider gears in the rear, Front is longer job cause takes longer to get axles out.
scrap--metal
MN
Calvin
'85, '81
K10, K20
His whole carrier is exploded! It's going to take more than spider gears to get him back on the road.
From his post #12:
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
From his post #12:
He was looking at my pics.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Wrong pictures you're looking at. Those are my axles!
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
From his post #12:
Yep You guys are right, Never seen this pic Change the whole Damn thing and go.. lol.
disenough
Rock Hill SC
brice
I have a 10 bolt that's open with 3.73s.
I'm in Rock Hill.
Also the junkyard here has a few just don't know the gears.
gmbellew
Kansas city
glen
suburban 1500
just happened to me, same rear axle ratio and G80. I had it rebuilt with a truetrac instead of a other G80.
kodyg86
