Rear disc brakes on the cheap
I'd definitely hit up the forum vendor, clkelley, for this! I've used him a couple of times and his prices and product is second to none!! :waytogo:
robzkool2
Panama City
Robert
this is something i have been wanting to do for a while. has anyone done this yet? cheap,easy and off-the-shelf. heck yeah! but will it fit in a 15"x10" rim?
Big Paul
Richardson
C-10
Rear brakes
I`m wondering what kinda caliper brackets did you use ?? The clip on type or the welded type ?
belowaveragecustoms
Oklahoma
Clayton
c10 short bed 2wd
Either one will work. if you don't have access or knowledge for welding, the bolt on will work just fine but if you don't mind laying some beads, then have at it.
Big Paul
Richardson
C-10
Thank you for your response !
I can weld and have a mig welder ! So I need to purchase an 2000 Astro caliper bracket for my 84 ?.... What angle do I need to weld the bracket at ?? Do you remove that dust cover too ?
4thgentruck
South Carolina
c10 shortbed stepside.
Has anyone donebthis conversion yet if so could u list a step by step and parts list please.
I have a 77 c10 stepside with a gm 12 bolt.
Big Paul
Richardson
C-10
Does anyone know ?
Has anyone done this brake conversion yet ?
If so can you supply info on front or rear calipers from the astro van for rear brakes on chevy, any detailed pics, and a complete parts list :hidesbehindsofa:
cedens
Oklahoma
Cliff
305 4bbl
silly question for us 4x4 guys... would disc setup from a 00 or newer work, those have been 6 lug, my dad's 2000 stepside has them, my 03 stepside had them, but my 06 sierra has drum on the back.
or is the lug pattern different from the 4x4 to the new 6 lug or do i need to next time i get a wheel off try one of my spares (even though they are 17" or 16"s)
Unpredictable1
AB
LB
Sierra Classic 1500
New member here chiming in - hopefully someone grabbed photos of doing this as I would love to change mine to rear disc on the cheap.
I'd need to keep the hand brake though.
Ty'1987
Lansing, mi
Tyler
I think gm has used 6x5.5 for all of its products. As for the rear discs fitting, I would reckon its possible but only with fab work.
I have read this thread and it got me interested in doing my own 6 lug rear disc swap. But I couldn't find any sort of bolt in or weld in caliper mounts to make it happen.
Best bet would be to take the whole rear system, mounts included, from a donor 6 lug Astro or truck. After taking pictures and measurements of caliper position relative to frame, rotor, and axle, design a "mount for a mount" to get it in correct alignment. Then plumb some custom brake lines and add a proportioning valve somewhere....
This all assuming the lug pattern, lug size, and wheel offset are exactly the same. Something tells me it can't be that easy!
Camar068
Kentucky
10 yrs Air Force
Nice website, new member here. Thanks Belowaverage for sharing and starting this post. I don't own a square body yet, waiting for taxes. This is something I wanted to do once I decided to go square body. I remember the PITB drum brakes I had on the camaro....boy they sucked.
So being new to the vehicle and rear ends in general, I guess the mounting plate for the bracket is also required? I didn't notice any mention of it in the original post.
Thanks In Advance
'Maro
HAZZARDJOHN
Medevial England Iowa
V1500
Ok, I have no dog in this fight, but why not use 94-96 Impala ss or Caprice 9C1 rotors calipers and what not for 2WD? They have four wheel discs and 5x5 lug patterns on an 8.5" rearend.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I've been thinking about doing just that. There's a Caprice at the junkyard usually that has them.
jlyon1006
