REALLY need help here
cutawayquick
Have a '75 chassis and drivetrains,I think, np203 transfer case which is at the shop receiving part time conversion. Something that I have not seen mentioned here, I HAVE 2 tcase shifters. What is the shift pattern? HELP PLEASE!!!!!
Sent from my QTAQZ3 using Tapatalk
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Not sure I understand the question. NP203 has only 1 shifter but 2 shift rods. Are you referring to how it is hooked up or has it been twin-sticked? Might need pics and some more description of what you're doing.
Don't mean to sound dumb, but doesn't a 203 already have a part time kit in it? The 205 was full time, or do I have that backwards?
cutawayquick
Not from all I've read. Full time and am installing g conversion from Summitracing I think p# mmk500. I have 2 shifters. Not sure if that was ever oem setup
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Lil backward there Mr Clean. 203's are the chain driven full time cases whereas the 205's are gear driven part time.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Gonna ask the obvious question.... You dont have a manual trans do you?
If not, one stick will control L-N-H gear selections, the other one controls loc-unloc.
Original shift pattern for a 203 is
Low-loc
Low
N
Hi
Hi-Loc
firebane
Calgary, AB
Curtis
NP203 = Full Time
NP205 = Part Time/Selectable
NP203 has 1 shift lever unless it was twin sticked. In which case one stick will control the locking mode and the other stick controls the shift mode.
There are two types of part time kits for the NP203. First kit is the entire assembly which is no longer made or the cheaper alternative which just a bunch of slugs and makes it part time.
The cheaper alternative has caveats that you need to be absolutely aware of.
cutawayquick
It has been 2sticked, and the way I understand it the conversion is "basically" a shaft, I think. Here is a question, for someone way more knowledgeable than I, shifter near the driver. 2w toward front, 4w toward seat. Shifter passenger low toward front, high toward seat? And if so, where is loc? I am frustrated... And I apologize for my ignorance, thanks for ANY help
firebane
Calgary, AB
Curtis
I just explained to you how the two sticks work.
Just since I'll be a nice guy and do some googling..
http://s52.photobucket.com/user/metaltwister/media/74 FSJ Jeep Cherokee/shiftts.gif.html
NP203 = Full Time
OK....had them backwards
Rusty Nail
Rusty
350sbc
Taken from the sunvisor of my '75 K5.
goodwrenchca
