Rattle in oil pan below 700rpms
87scotty
Central il
Andrew
V20
5.7 for now
good read glad you got it fixed
Wildjoe330
Right Now
wildjoe330
Itbp
2-3 weeks ago mine sounded like it spun a bearing, Turns out
the top of the power steering bracket was broken off at the
top bolt close to the bolt and someone tried to weld it back
(Still Broken) vibration sounded like a spun bearing.
Temporarily tightened all, bolts were dirty froze loose (vibration).
Noise went away ha, sounded so much better.
Just ordered a new ebay PS Bracket.
Camatruder
Belgium
Rik
K5 Blazer
350ci / 5.7l
@usar17 : i'm having the same issue, heavy vibration when locked up and trying to accelearte slowly (so the TCC keeps locked up). If the TCC unlocks the vibration stops. Is there a way to check ignition being good under load ?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Check for spark on all lines. I think there is a tool for that.
Sent from my SM-G950U using Tapatalk
brentjo
