77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
I've been looking online for weeks and still haven't found a clear answer if they will fit. I have an appointment on Thursday with a good exhaust shop and guess I will find out for sure then.
A few have said they fit on a 4x4 no problem. One guy said the driver's side motor mount gets in the way and he had to use a torch and cut part of the "clam shell" away to allow clearance for the flange stud.
Can anyone comment/add anything before I possibly waste a lot of time heading to the shop (it is 120 miles away).
Driving will cost a lot in fuel, but will be a good shake down test. A little while ago I found out I had a bad camshaft (lobes were round). Since then have installed:
-new starter
-new alternator
-new transmission pan called a slam guard. 3/16" thick, powder coated. Provides great protection.
-new airfilter housing
-new cam. "BLUEPRINTED 350HP 327 HYD SBC"
Intake Duration at 050 inch Lift: 222
Exhaust Duration at 050 inch Lift: 222
Duration at 050 inch Lift: 222 int./222 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.447 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.447 in.
Valve Lift with Factory Rocker Arm Ratio: 0.447 int./0.447 exh.
Lobe Separation (degrees): 114
So far I love it- but hard to hear how the engine sounds with a leaking passenger side exhaust manifold and the rest of the exhaust is rusted and falling off.
The engine builder suggested the 2.5" ram horn exhaust manifolds and some 2.5" Thrush welded mufflers to save a bit of $$.
-new starter
-new alternator
