clkelley
- Mar 31, 2012
- Galax, Va
- Chris
- 2500HD
- 6.6L
R1Concepts Eline Series Cross Drilled & Slotted Rotors
RECEIVE An Added 10% OFF With PROMO CODE= CK10
R1 Concepts ELINE SERIES BRAKE DISC WITH SILVER ZINC --
When price is important and quality is essential. R1 Concepts ELINE Brake Rotors offer many of the benefits of an OEM part at a fraction of the cost.
- Cross-Drilled and Slotted Design
- Drilled holes provide maximum air circulation for increased cooling
- Holes are countersunk which reduces heat build up
- Exclusive R1 Concepts Diamond Slot increase brake pads bite
- Diamond Tip use as indicator for brake rotor wear
- Military Spec Plating for rust protection
- Direct Fit OEM Replacement Brake Rotor
- Double disc ground finish reduces rotor vibration
- Meet Or Exceed OEM Standards For Excellence
- Mill balanced brake rotors ensures long lasting durability
- Brake rotors are casted using G3000 graded iron.
R1Concepts Secure Online Catalog
CLICK HERE TO CONTACT ME Or Post Below For Questions, Concerns & Complaints
