R134a conversion
chief_shotts
beaverton, OR
edgar
k30
I am in the midst of converting my system to r134a. I see alot of people talking about high pressure cutoff switches being necessary for r134a systems. I also see a lot of people who convert with no mention of using a HPCO switch. What's the deal? Is it necessary? And if so how do i go about adding it?
Sad Sack
Nebraska
Goober
C15
I converted my '85 over to R134 with just a new compressor, orifice tube and accumulator. The guy helping me said a new condenser would be a good item to throw in too but truck cooled down enough for me to be happy as-is with those three installed items.No HPCO switch needed. Your results though may vary.
chief_shotts
beaverton, OR
edgar
k30
Excellent! Thanks for the input. I installed new everything since my system was open for an unknown period of time.
Chevydad
Jason
v8
I installed the whole AC system, no high pressure switch. It does have a low pressure switch.
Install a pusher fan in front of the condenser. And wash the condenser.
dd1990
Oxnard, CA
Suburban 1500
I converted to r134 with a sanden compressor with no high pressure switch. The Compressor had a relief valve so if the system is over pressurized you will just loose some freon. That being said if you use the dual gauges and don't overfill I wouldn't worry about it.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Some systems came from GM with the high pressure switch and some came without. My 1987 V3500 did not have one from the factory.
Since you replaced everything make sure you have the correct amount of PAG oil and charge it to 80-85% of the R12 specified charge. Don't overthink it.
chief_shotts
beaverton, OR
edgar
k30
yes i believe its 10-11 oz of pag and 80% of 3lb 8oz... so about 45 oz of r134a
dpenfield
