Question about air cleaner lid flip
Craig 85
Nashville, TN
454/TH-400/NP205
Here's what I did on my '79 K15 (small block). I got an '81 and up air cleaner lid & filter, which is 2" taller. IDK if it works with the '87 TBI or if it would be too tall. I purchased the cold air tube and cut the end off the diffuser at the core support. Creates a ram air set up.
This is my '85, but same idea.
Keith Seymore
Motor City
Keith Seymore
4.3L
Well, if you guys were interested in an estimate on how much of a difference intake air temperature can theoretically make it can be estimated with ideal gas laws. Since we always want about the same ratio of air to fuel we can focus on just the air and assume it's bringing proportional fuel and power. Say 70 outside temps and 120 under the hood, that's about 529 and 579 in Rankine. Gasses expand proportionally with temperature so density goes in the inverse of temperature. So 579-529=50, 50/579=8.6% decrease in volume or it's at 91.4% of what it was. Density = m/v, so 1/.914 = 1.094. So by dropping 50 F from 120 you should pick up 9.4% hp, not to mention you should have a cooler running engine and improved efficiency. Now if the intake tube is restricting flow this would of course offset the power gains, but I think that if you're moving air is actively being crammed into the intake tube, so I bet you're actually getting more flow with the tube than with a flipped lid once you're past 25 mph or so. If that's the case it might be in the ballpark of 15%.
The gains from the cooler air overcome the losses associated with the added restriction from the tubing.
K
Keith Seymore
Motor City
Keith Seymore
4.3L
That's what I did on my Chevelle (using truck parts, of course). I ran that setup for years and years; It was worth .2 sec reduction in ET in the quarter mile.
K
Big Heavy
North Alabama
Bryan
C15
I think this is a good setup for flow, and may even sound good.I was posting this while Keith was working on his with similar idea /\. I have had mine flipped for years but plan on going to this style.
vkh
Western Montana
Var
C2500
K
I was saying I think that while you're moving enough air is being pushed in to overcome the restrictions. So denser air and a larger volume of it, win win.
vkh
Western Montana
Var
C2500
I've done the same thing with mine. I don't have pictures and haven't run it yet but I like it.
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
Well this is all fine and dandy IIIIFFFF everything is ideal and in the real world, it is not. But even if were, 1.094x180=196-20%(drive train loss)= 157 whp. Stock @180= 144. You should feel 13 whp... but you wont as in theory is fine and dandy in theory but not application. Also even if 13 hp was added, who are you racing with 157 hp and 5000 lbs? That Honda will beat you, its half the weight. And 13 hp isnt going to give you 13 ft lbs of torque either.
And last note, if you have your egr hooked up... Its heating the intake air anyways. So you are loosing that cool air effect.
Ram air is a methodological beast. In order for ram air to work, you have to be doing something like 100 mph. I forget the math on it, but we tested it on 4th gen F bodies and basically, it doesnt exist. Pulling in cooler air does help atomize the fuel better, but once again, if you have an egr valve connected, your heating the air up anyways. Also, the air box is metal, sitting on some old american iron, so once again, the air is being heated.
Still, that all said, Its better running the tube if you have it, but you wont notice the decrease in performance running an open filter.
We could get into advance thermodynamics and physics and blah blah blah, but simply put its not going to change things. Its great for very small changes and environments (not the environment, that's a different subject on a much larger scale.) But just remember basic chemistry and physics, heat moves into cooler spaces.
vkh
Western Montana
Var
C2500
Doesn't egr only draw when your engine is cold?
ajd89
Central Michigan
andrew
Probably a stupid question but Did some trucks come with the dual intake or is that something you make up?
vkh
Western Montana
Var
C2500
To my knowledge no truck came with it. I believe some performance cars had dual snorkels though. Anyway it's really easy to fab up on these trucks since there is an extra cutout on the other side of the radiator, just punch it out, and another snout onto your air cleaner and run some tubing.
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
And stickers are good for about 3hp a piece lol
Don't forget chrome valve covers,chrome air cleaner lids,and racing stripes. Valve covers=15 combined, air cleaner=10,racing stripes=25.
Iowan
Iowa
Calvin
K1500
350 crate
But I would just like to know where to buy a oem 4 barrel cleaner?
Doug Hampton
