firebane
- Jul 10, 2014
- Calgary, AB
- Curtis
- K10
So I know we are all looking for those ways of getting our carbs to suck in MORE cool air for that extra little bit of OOMPH. My stock air cleaner looked like this and I knew it was just not going to work.
So off to the PNP pull yard and found 1 truck that had a TBI air cleaner on it and walked over to another with a qudrajet and plopped it on. It fit without ANY modifications to the air cleaner housing and takes the exact same element as the old air cleaner.
So I brought the TBI air cleaner home and tried to bolt it up but realized because the TBI air cleaner is a drop base that I was unable to screw the lid down. I took a 1/4"x20 coupler and took two qudrajet studs and put them together to make one longer one. I will be replacing this entire setup with a new piece of 1/4"x20 ready rod but for now it locks down.
Afterwards I realized that since this worked I needed to find a way to pipe the air cleaner to the front of the truck and found a old S10 blazer that looked like it could work but the end was too small.
So back to the wrecking yard I went today and found exactly what I needed. I'm not sure what trucks these come off but its another factory piece for TBIs that will pull air from the front of the truck. I brought this home and was able to bolt it all together. I am about 3-4" inch short from connecting it to the stock area so I will pick up some tubing to finish the connection but for now it looks like this.
So if you are looking for a way to do this.. scrounge up the TBI parts and give'er.
