Q: Trick to Reattaching Speedo-Cable
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
Please Help Me:
How in the world do I get my hands behind the gauge cluster so I can attach the speedometer cable to the gauge cluster.
My issue is there is no space to get my hands back there.
Q: what's the trick or technique
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Seems like I put my back on the floorboard and reach up and feel where the spring prong and speedometer end is and guide the cable on. Just a 1 hand process and by feel. You might be able to see the speedometer end with a flashlight and having your head up in the lower dash, but you won't be able to look and install it that I remember.
Good Luck!
Britt
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
thats a damn good idea
thxxx
You also need to push firmly but carefully until the flared end of the cable gets by the spring clip and is held in place. The speedometer might initially work if it’s not fully seated, but it will eventually pop back out, or make the needle bounce later.
Scott91370
Burleson, Tx
Scott
Sierra1500
Is the cable not long enough to take the cluster out, connect the cable then put it back together?
85K304SPD
Las Cruces, NM
Richard
Pull the cluster and do it from the front as you put it back in.
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
Yessir
Y'all my Brothers from another Mother lol
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
Good Luck!
Britt
boloboss
Houston Texas
Shuntel
Chevy C10
v8 350 5.7 liz6er
Good Luck!
Britt
wywarner
