tjw82c10
- Mar 11, 2025
- Los Lunas, NM, USA
- Tyler
- c10
For the life of me I cannot find a thread with the question I need so if its already been discussed I am sorry, decided to just go ahead and do a 5.3 swap on my c10 cause my dad did make a good point of not spending the 2k on rebuilding the 305 and just go ahead and do the LS I already wanted to do so I am essentially saving the 2k by ditching the 305. I want to run a carb set up just because its simple and in a sense the cheaper way to get the LS up and running. Ive read alot of the forums that talk about the fuel pump issue which I know regardless that its going to have to be adressed one way or another. If possible I want to avoid replacing the fuel tanks with 1987 ones for the fuel pump and baffles. Would it be possible just to run an aftermarket frame mounted fuel pump? I also just watched one of the Brothers truck and parts videos and I guess they have a fuel pump that works with 73 to 87 stock fuel tanks and has a "soaker" to solve the issue of losing power while cornering. Anyone have any experience with any of this? Again apologies in advance if this has already been discussed.
