Pumping Air to a Catalyst
1lejohn
texas
john
k-1500, 2500 HD
I want to install cats on my 85 truck. It has headers and dual exhaust. The cats will have to be mounted far back in the system. The stock air pump brackets, fittings etc. are long gone. I would like to go back with them, but they are hard to find. I have an electric pump from a car that I think would work. My thought is the pump would only need to run at start up to help the cats fire off. A couple of check valves welded to the pipes and some hose from the electric pump might work. Has anyone tried this set up? Thoughts concerns?
I know nothing about electric air pulse pumps,but do understand how Mazda and Mitsubishi did it without air pumps of any kind. You might want to investigate some,it may be the simplest way. Basics is at Idle a vacuum operated valve opened a valve. This valve allowed air from the air cleaner to the catalytic converter to pass back and forth. A reed valve in the air cleaner kept exhaust pulses from going into the air cleaner on a positive pulse but allowed air to be drawn on a negative pulse. No parasitic draw from a belt driven pump,no electric pump,just exhaust pulses and reed valves.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
GM warmed the converters in the most reliable way at the time. Meaning they calibrated a cold start with increased idle speed, delayed the converter clutch from locking until the engine reached a certain temp, all to keep engine rpm higher.
They use the same strategy now, except the disable some of the higher gears in the transmission, and moved the converter itself closer to the engine.
I would think as long as the engine is tuned correctly, holding the engine at a higher idle speed right before an emissions check should be good enough.
ali_c20
Austria
Alexander
C20, K5
You can wrap the exhaust pipes to the cats to warm up quicker and keep the exhaust gas temperatures high. After market race cats are pretty slim and could be mounted closer to the headers in your system.
mibars
Nadarzyn, Poland
Michal
Suburban V1500
In an S2000 I had some time ago an electric pump run for a minute after a cold start on a timer and it shut off during acceleration. I guess you could make it vacuum controlled.
That's a good idea, both moving to a small metal sports cat converter closer to the headers and wrapping the exhaust & headers to keep the heat in. It will help keep the engine bay cool too. I've used a Magnaflow cat in all my cars so far.
I was always wondering why the torquer converter is not allowed to lock on a cold engine, I though it had something to do with viscosity of the ATF affecting how the clutches would be activated when some of the flow was to be redirected to the converter clutch. If I recall correct there is a temperature switch inside 700R4.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
Locking a torque converter on a "cold" engine could allegedly cause driveability problems. GM allowed torque converters to lock at about 125F (engine temp) on various platforms, which is still quite cool.
1STLS1
West Phoenix AZ
MIchael
I also was thinking of running an electric air pump for the converter to comply with the fact it requires one for emissions visual check, I thought some GM vans used this for a while, mid 90's?
Last time running one through, he was only concerned with the vapor canister portion and it was functioning although it did pass the dyne drivability test.
77Dmax
vt
Joe
I believe LT1 powered fourth gen F cars had electric air pumps. I remember the vacuum cleaner noise to go with the vacuum cleaner looks...
SquareRoot
I went through this on my 85 with the help of Magnaflow engineers. Bottom line, if the cats don't get hot enough to fire off, it's all a moot point. I have a thread called " going back to cats, enough is enough '.You can see what I did to make it work. If you're heart is set on dual exhaust, don't waste your time.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The temp switch automatically locks the converter if it gets too hot. The theory is a locked converter will reduced heat.
Of course, by the time the transmission is hot enough to trip that switch, the damage is probably already done.
1lejohn
texas
john
k-1500, 2500 HD
The cats not lighting off is what I'm worried about. The air pump is out of a LS1 Camaro. Looking at my exhaust the driver's side cat would go in the stock factory location. The pass side about the same distance back. Mounting the cats off the header collectors is not an option. The pipes make a bend and go over the transmission crossmember. I'm not worried about tech inspections here in Texas. I feel that putting the cats back on is the right thing to do for a daily driver. I read your thread. It has a bunch of great info. I don't want to rewrite the book to do this, or spend a whole bunch of money.
winfred
port allen la
winfred
c30 v2500
the cats will eventually light, they don't have much of a choice being fed 600-1500 degree gasses, my old job was working on euro cars and they all had that electric air pump, it's a piece of garbage, and if the valve leaks a little, the pump gets killed via drowning in condensation as a bonus
most of the stuff that has the pump, has cats right up on the manifolds, so heat is not an issue on that
if the converters aren't going to be a length or two past the output of the trans i wouldn't worry about it, most cheap aftermarket cats aren't very effective anyway, and are typically dead in a couple years
1lejohn
texas
john
k-1500, 2500 HD
I never thought about it that way. I guess I'll check some shops and find out how much it will cost to add them.
LuckyDevil77
