Pumping Air to a Catalyst
1lejohn
texas
john
k-1500, 2500 HD
I want to install cats on my 85 truck. It has headers and dual exhaust. The cats will have to be mounted far back in the system. The stock air pump brackets, fittings etc. are long gone. I would like to go back with them, but they are hard to find. I have an electric pump from a car that I think would work. My thought is the pump would only need to run at start up to help the cats fire off. A couple of check valves welded to the pipes and some hose from the electric pump might work. Has anyone tried this set up? Thoughts concerns?
I know nothing about electric air pulse pumps,but do understand how Mazda and Mitsubishi did it without air pumps of any kind. You might want to investigate some,it may be the simplest way. Basics is at Idle a vacuum operated valve opened a valve. This valve allowed air from the air cleaner to the catalytic converter to pass back and forth. A reed valve in the air cleaner kept exhaust pulses from going into the air cleaner on a positive pulse but allowed air to be drawn on a negative pulse. No parasitic draw from a belt driven pump,no electric pump,just exhaust pulses and reed valves.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
GM warmed the converters in the most reliable way at the time. Meaning they calibrated a cold start with increased idle speed, delayed the converter clutch from locking until the engine reached a certain temp, all to keep engine rpm higher.
They use the same strategy now, except the disable some of the higher gears in the transmission, and moved the converter itself closer to the engine.
I would think as long as the engine is tuned correctly, holding the engine at a higher idle speed right before an emissions check should be good enough.
ali_c20
Austria
Alexander
C20, K5
You can wrap the exhaust pipes to the cats to warm up quicker and keep the exhaust gas temperatures high. After market race cats are pretty slim and could be mounted closer to the headers in your system.
jdodd5
