Pull 6.2 and 700r4 as a unit?
dudewiththeblue82
South Carolina
Calin
6.2 diesel
I've got a 1982 c10 with the 6.2 diesel and 700r4 trans. Long story short the starter mount on the block cracked (unbeknownst to me the starter bracket was missing so the starter kept moving around while cranking), and I need to pull the motor to have the block welded. I hear the diesels have to be separated from the transmission before pulling, but I don't know how true that is. Has anyone here attempted this before? Thanks
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
I've pulled them together using the factory motor hooks. I usually pull the front core support and have a jack helping the back of the trani. Don't know if I would want to try doing the old tip and slip in and out method with that combo.
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
With the radiator core support out, I don’t see why it wouldn’t come out as a unit. Just make sure your crane is up for the job. The 6.2 is much heavier than a 350.
Ben
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Why not if the lift is strong enough and you have the headroom?
Ben
Does the 6.2 weigh more than a big block..? Like I mentioned above with Originalguy if the lift/crane is up to it why not? Even with the rad support in... lift the tail and/or crank the waddaya call it a load balancer. Those screw things that moves your connection point forward or back. Which btw is a tool that once you use you never want to do it again without!
Yeah tip and slip..! Initiate the tip right from the get go. Before the engine is off the mounts the tail should start to come down. Hydro wheeled floor jack works perfect under the tail and start lowering like I said as soon as the front is coming up.
If your engine crane is fixed then you have to pull the truck backwards and out from the hanging block/tranny. An engine crane on wheels needs a smooth level floor to roll backwards with the hanging jewels.
Rickf
Grafton NH
1974, 1954 & a 1937
The 6.2 can come out by itself, unless the 700 also needs attention I'd leave it in. The last time I pulled a 6.5TD the truck needed fenders and a core support so I removed the entire nose.
fast 99
Spokane, Washington
Have pulled a few 6.5's with manual 5 speeds. Unless there is a reason to remove the trans leave it in. Only had to remove the rad and hood. Yes, they seem to be heavier than a big block although I never weighed one.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
yes you can! :D
Strick
Dunn, NC
Harold
C20 Crew
yes you can! :D
That is a "man" of an engine crane you have there! My engine stand and crane were screaming this past summer when I put a 6.2 in a Silverado K5. It had a broken crankshaft and it was aggravating getting the torque converter bolts out. Thankfully this was accomplished and I didn't need to pull the transmission too. It would have been terrible because it was also 4x4.
Strickland
Albrigap
South Dakota
Alan
Suburban
Remove the hood and drop the rear transmission mount and the engine/transmission will easily come out.
Even with the transfer case on it.
No need to pull the radiator support.
The 6.2/6.5 are roughly the same as a big block.
Done it many times.
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
Strickland
this is a cheap $150 engine remover! ;)
Big Ray
North Carolina
Ray
82- so called "red block". Desirable 6.2l.
Chevy Legend
