Project Mini me
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Still got two things to wire...
The "key in engine on" wire I need to find...(crimp there no wire)
I need a fuse and fusable link....(wires there)
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
So I take it she took the probe with out tearing anything..oh yeah don't eat your kitty....we don't eat our kitty's how about a hot pocket?
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Probe went in smooth....went to O'Reilly s for fusable link , fuses, wireyahoo, and eyelet to go in battery nut crimp. Will install later when heat dies down...
Picked these up...
The beeders are for samurai, but I think they are the same....
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Nice. I hope your gonna post some vid of this thing doing some sweet jumps.
So Project Mini Me is coming along great. When does the square start to get some lovin' again?
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Ya know I didnt think about jumping her, just mild off road trails and expedition cruising, but that sounds fun...
I am at a standstill... It sucks because I planned on pulling a $800 junk body with good engine one next to her for a heart transplant, but with the potential to have authorities involved again, have done nothing... I saw a guy who does fences that swing in, so my only choice is likely moving it to the back yard, or kickin it dowm the road which with so much time in, I am not ready to do.
But I got the fusable link in with 20amp fuse.. If it blows I can go up....
I kust need to tap into a good key in engine on wire, and it should be done deal with the fan... Last time I think I ran it to distributor on regal....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
You gotta jump it once lol
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Tapped the wrong wire yesterday, so had to undo that....
Doing more research on fuse panels..
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I am hoping to tap into an existing wire...
Without having to get into this...
This is what had me splicing into blue/black, but apparently, it was black/white I wanted...
Stretched out in the floor with a Chilton/Haynes, and this guy got involved...its crazy how cats can be brithers but look like different breeds...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Well I went out again with good intentions... Its 104 today so I called it after another hour or so..
Took the fuse box off fender to see aboit the "black/white" wire... Dont see it amd supposedly haynes is commonly wrong on this due to different models...
The ignition wire is 60amp white and green wire...
But before splicing into it, I ran the power wire straight to the engine...and after firing her up and letting her heat up, it mever came on, so while not trying to overheat, turned in ac and stock ac fan cooled it down fairly good on its own...
So I dont know if the module/ controller is bad, or I need to just basic wire it to see what is the cause.... I am starting to get cross eyed and figure I'll do better when it's less hot...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I downloaded 800 pg fsm offline...for these three pics to help, but there was another book, just for wiring, so didnt find specifically what I was looking for, but again said B/W wire was ignition...
But I am done playing around so bought these for $12...
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
The logic probe is way better then a test light imho. Only thing better then that is a power probe but if you don't know what your doing with one you can try all kinds of stuff.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Went out today and found out the fan and controller works...with direct power from batt. Now will see where key on power is...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
The logic probe was worth every penny. I have only had the one that logjts up for positive, but not red for positive, and green for negative... Should make finding key on easy when im off next
ExtraZ
