I found the PCV on the passenger side, and that came right out, since I had already replaced that and the short plastic pipe to the throttle body base. This seems to be just a molded black plastic pipe stuck in a grommet on the drivers side. It goes to a metal pipe connected to the throttle body "collar". Attached is a photo, TB pipe has been removed. There are some wires in the way that are wrapped around/attached to the pipe I'll need to move.
I've yanked up on it, twisted it, and used a flat head screwdriver as a pry bar with a wood block on the valve cover as a pivot point. All this after soaking it down with PB Blaster. The pipe will come up maybe 1/8" out of the grommet and the grommet moves very slightly but will not come out of the valve cover at all.
That's why I asked such a dumb question. It's like there is something retaining it from the back side, as impossible as that seems. I'll figure a way to get it out of there. If Dorman makes a replacement, I'll just cut it off and get another one.
