Power Windows Troubleshooting Info
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Thanks so much C10MixMaster, you've provided a LOT of great info. I appreciate it. Unfortunately, I still have more questions (sorry!)
1) Where is the circuit breaker on your 77? On the 2nd page of this thread (post #20, Jul 6, 2013 by HotRodPC) there is an attachment "FuseBox85K1500.jpg". It shows the circuit breaker as a silver box above the 20amp Yellow Choke Fuse. I do not have a circuit breaker in that location, and I don't think I have any circuit breaker on my fuse box at all. Or have you answered that question in your post #43 that says "the breaker near the brake booster", meaning that the breaker is on the firewall, not on the fuse box? If so, did you draw the smaller blue circle around the breaker in the first picture?
2) Can you please explain what you mean in your post #43 that says "then to a relay that's powered by acc. on the brake pedal assembly (behind the radio)"? You mean the relay is on the brake pedal assembly (???) Are you saying to get behind the radio to test for power between the breaker and the relay? Is that what you're illustrating in your second picture? Is your radio removed in that picture?
3) Yes, I believe someone put aftermarket doors on this truck, and that they are 1982? 1982? -1991 doors. Thanks for explaining the early system vs later system. I had no idea. I gotta trace the 6 wires and see where they go...
1) yes the breaker is the smaller of the two blue circles on the first pic.
2) yes the second pic is without the radio in the dash, and the relay is on the brake pedal bracket , you looking at the passenger side of the bracket about 2-3" behind the firewall..
Mark80K15
Sicamous, BC
Mark
K15
Ok, thank you C10MixMaster, you've been a LOT of help. I'll check it out and get back to this thread.
USMC Hitman
Phoenix
GMC Jimmy
5.7L V8
Lots of good info here. Following this thread since I have some of these issues.
custodian
Catawba
William
5.3 LS, 350
I've put new window motors, switches on both sides, and connectors and have been working fine in the 85 C10 until today. The passenger side works but the drivers side doesn't. So, I checked fuses, okay. Checked for power on the drivers side, NONE. I made a jumper wire and ran power from the under hood junction box to the switch, worked. I believe I have a broken wire between the door and body.
The wire loom between the door and body is still intact and not rotted and don't want to cut it open. Can another wire be pulled through without alot of trouble?
Yes. Just tie the new wire to the old one to pull it through.
custodian
Catawba
William
5.3 LS, 350
I got around to fix the wire problem, no way to just pull the wire threw. The wire harness was wraped with tape. I had to push the entire wire harness back threw into the cab. I found three wires broke, window and both power lock wires. I had to just use butt connectors and push the wire harness back where it was. Working fine so far.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
here my test bench for testing power window/door lock look like if that can help some one! ;)
Siningbd
2500 Suburban
Was able to prove out today that I've got a broken ground from the drivers switch back to the harness. Has anyone gotten creative with wiring solutions or is it best to just simply pull the harness back through the door splice it back together and pull it back into position?
Washington
Bringing this back up. Power windows just went dead. Coincidentally after replacing the heater core.
Made sure the pink and orange wires out of the fuse box have power. Circuit breaker on fuse panel has continuity.
AFAIK they worked the last time it was driven.
Wires are in proper oe locations on fuse panel although windows always worked with the key off. (I figured someone moved the link wire to an always hot plug on the fuse box , previously, but the pink wire is on an ignition controlled pin.
So window power may be pulled from somewhere else?
Any suggestions are appreciated.
Washington
Also the pink switched wire has on off power w/ ign on off even with the circuit breaker pulled. Weird
Obullard74
