Power Steering
kit141a
Mn
Bob
silverado
Tried to follow another thread. but not same thing I have. 1986 5.7 with air.
Power steering belt is loose. This belt also operates what I believe to be some type of pump (vacuum ?) I loosened the slider bolt and the two bolts that are on the pump. Still not moving. I am sure there is one more bolt on the steering pump that I am missing. The only one that I see is right behind the pulley on the top. Which I tried to get a wrench on but due to the bracket unable to Thanks
yeti_87
