Power steering pump replacement question
K10eddie
Connecticut
Ed
So last weekend I installed a summit racing v belt bracket setup on my 383. The alternator brackets and pulleys are fine, but the power steering pump bracket was designed to bolt to the front and rear of the pump. My current pump has no mounting provisions on the back, no bolt holes or studs of any kind. Is there a pump that has this? The problem is that the pump is bending the brackets since there's no rear support on it. Also I'd like the pump to be a keyway style if possible since I already have a new pulley for it. Sorry for the bad pics, but hopefully it's enough to let you guys know what I'm referring to.
HeeHaw_1980C10
