red84k10
- Apr 2, 2013
- Fairview NC
- Brock
- K10
Just re-wired mine this weekend. Not sure on a 85 but on 84's there is a ground block behind the driverside a.c. vent. The power window switch wire harness grounds there. Mine had came off and my windows would not work but my volt meter was showing 12 volts going in and coming out of the switch. Plugged it back up and Presto my windows started working again. If there is a poor connection there it could cause the windows to go up & down slowly. Hope this helps.
