Post a picture of your Rim & Tire
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Don’t do it....
Cmon man you know it looks good if done right. 18s are the biggest you should go. 17s to stay meaty. I wasnt talking about polished American Forces lol
No rake tho lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
No rake tho lol
I suppose that’s acceptable.
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
Kim Burke
Northern IN
Kim
C1500
I like how they look but I've bought 5 wheels trying to get 4 straight ones(still only 3). AERO makes some pretty crappy wheels.
275/60R15's on 15X10"rims w/5" backspacing all way around. Stock spindles and clearanced the crap out of the uppers. I think drop spindles would have eliminated some of the clearance issues. If I had it to do over, I'd buy a better wheel but this set up has ZERO tire rub, lock to lock and to the bump stops.
Paul Dudley
Lapeer, MI
Does anyone know where you can buy stock steel 16" rims for a 6 lug? I have a 1984 K10 and it has the factory 15 inch rally wheels. The truck is geared low, so I want to get a higher profile tire/wheel combination so it can run at freeway speeds. I like the stock white work-truck wheels and would like to start with a 16 inch rim and then a figure out a high profile LT tire.
Is there a 17 or 18 inch stock steel rim for a 6 lug? Probably 16 is the largest. Also, does anyone know the spacing between the studs for the stock 6 lug axles?
Thanks
Should be easy to find on Craigslist or facebook marketplace.
Thanks
What's the current ratio? Most K10's in the early 80's were equipped with highway gears. What's the current tire size and what RPM do you run down the interstate?
Factory 16" white steelies are super duper rare in 6-lug, and I believe were an option in the late 70's. And the bolt pattern is the common 6x5.5" that was used on newer trucks too, but the newer truck wheels have a smaller center bore and more backspacing.
BLAZENK5
