Points vs HEI vs WHAT?
firebane
Calgary, AB
Curtis
Wealth of info as usual :) Thanks guys!
What's a compatible tach? I would love this one but it's too expensive:
http://www.gmsports.com/content/new-tachometer-1973-1988-chevy-and-gmc-trucks
So what about something like this on eBay? Would this be compatible? I'm assuming there is some way to adjust whether you have a 4,6, or 8 cylinders? And I sure hope I can turn off the backlight!
http://www.ebay.com/itm/2-52MM-RPM-...-US-/111347361481?hash=item19ecd1e6c9&vxp=mtr
I know it looks ugly and cheap but if it works, it works. I can always buy the nice expensive one later when i can afford it :)
If you look at those tach pics you'll see a switch on the back. It will allow the 4-6-8 mode as you speak of.
Chaz
Chaz
V1500 Suburban
350 tbi/th400/np241c
Ok so why would a points type ignition work during/after an EMP and an HEI system would not,,,the points ign has wires and what a condenser to fry too,,, if you carried a spare hei module to bolt back in the the dizzy would that work or would that be fried too,,,,and I have to say I had a 69 Cadillac with a 472 motor that had points,,,when I adjused the gap I always did it with the motor running using the small access door on the side of the dizzy with an allen wrench to set the gap and using a dwell meter,,,,that bitch ran as smooth as any HEI system ive seen,,,,
mistaake
SF Bay Area, California
Michael
Crown Vic
Why does it matter? Gas station pumps even those that older mom-and-pop stations still use are electronically controlled... So even if your truck runs after an EMP you won't be able to fill up which is a problem at 5-15mpg.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I'll take a 6.2 diesel...no electronics to run the engine other than a glow plug controller which could be manually controlled.
mistaake
Michael
Crown Vic
But you can't fill up on diesel when the gas station can't pump it out. :D Just sayin'
There are ways to get fuel out of the underground tanks at stations. Worse case scenario, a 5000 watt generator will certainly run the pumps to get fuel to the dispensers.
I had a buddy that built gas stations from scratch, and also replaced tanks and dispensers on retrofit upgrades especially when Cali went to stricter EPA rules. I helped on a few of those jobs and know a little bit about a little bit on how those systems work. Trust me, I'll be getting fuel if **** hits the fan.
Most don't realize, as we say "pull up to the pumps", we don't actually pull up to the pumps. We pull up the dispensers. Most stations will only have 1 pump on top of each tank the holds each grade of fuel. The pump is on top of the tank and pumps to all of the dispensers that do nothing but measure the amount of fuel and calculate the total cost by price per gallon. There is also a vapor recovery system that feeds into the tanks from the dispeners.. hint hint
firebane
Calgary, AB
Curtis
HEI is far superior and more reliable than points.
With that said it doesn't sound like your having fuel issues but something else.
Nawww, there's no fuel issue. The convo just took a different turn. I think he's got all the info he needed about the difference between points and HEI, then it went astray.
mistaake
Michael
Crown Vic
So that tach arrived. Well, I don't see the switch to select cylinders? WTF!?
Well then, let's hope it's a V8 Tach and set for 8 cylinders. You don't know til you hook it up. Maybe it's one that has the be taken apart to set up? Any instructions come with it?
firebane
Calgary, AB
Curtis
Sometimes you need to take the back cover off to get to a switch as well.
mistaake
Michael
Crown Vic
Yep, that was the case. I had to pry it out of the cup thing it was in. It was in there really tight.
1986ChrisK10
hey, i don't mean to bring a thread back from the dead.
I did learn a lot from this thread, and I am leaning to a bad module.
But would/can the ignition control module go bad with truck running at idle? The reason why I ask is cause I had the 86 K10 down by the road unloading trash for the county to come pick up. Jumped back in the truck went to give it gas to park the truck and it died. Not getting any spark. Thanks fellas.
SlickGTP
Houston, TX
Entirely possible for it to die at any point/time... The modules are heat sensitive and if it overheats then it's just a matter of time before it just conks out.
If you replace it, then make sure you clean off the mounting pad real good and put some new heat transfer paste back on it before installing the new module.
86mike
