- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
((((((((((((((((Helllooooo in here........))))))))))))))))))))))
((((((((((((((((Helllooooo in here........))))))))))))))))))))))![]()
You got that right, sorry!Kinda hard to buy from them, or get any answers if they are never here!
I think I might have found the kit I will use, narrowed it down to one of these:
1. Stay with a stock replacement.
2. Heartthrob manifold back dual kit with dual converters, factory mufflers, mod the rear pipes to exit under rear bumper on each side of the receiver hitch with dual 3" x 18" chrome exhaust tips:
http://www.heartthrobexhaust.com/8141460.PDF
http://www.autoanything.com/exhausts-mufflers/gibson-slash-exhaust-tip
3. Cat-Back Aftermarket System:
http://www.autoanything.com/exhausts-mufflers/61A2906A0A0.aspx
I did not purchase anything yet but will be in the next 6 weeks. Keeping stock Y-Pipe, adding new Walker cat, int pipe and muffler, and going to have a local shop build a muffler back dual rear under bumper exit with chrome tips.
OK so the
(1) 15693
(1) 42364
(1) 21054
(or AP Exhaust equivalent)
Any clamps? 35794
2 pc 31398 Gaskets
1 pc 35362 Bracket
4 pc of these: http://www.gotexhaust.com/i-14138077-borla-18006-stainless-band-clamp.html
The rest I will have the shop make up and install unless you can come up with something I can install myself.
What is your price on a converter?
How about this, having a real hard time finding this configuration.
What about using a small transitional pipe with this muffler? I don't believe you will find the offset in / dual out because that would take some tricky bends inside the muffler.
http://www.gotexhaust.com/i-1413740...ce-exhaust-12278-stainless-steel-muffler.html
Right on, 3" single should be about right, if not a little big, using conventional wisdom. Going too big on true duals can be quite counterproductive so I agree with you there as well. Thanks!
