mtnmankev
- Jun 10, 2014
- Ash Fork, Arizona
- Kevin
- K10, C20
- 383 Stroker, 350
My truck was all over the road, I found the pinch bolt on the pittman arm at the steering box needed to be tightened down. I cranked on it with wrenches as hard as I could working with the limited space there. I am hoping the splines didn't get damaged as the arm is not available from parts houses. I still need to make the 45 minute (5 mile) trip to a paved road to do a good road test to make sure that fixed it. How tight do you guys crank down on the bolt? It's a grade 8 so I know it should handle a lot .....
