Pilot Bushing ? for the masses.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Should I keep going? How many examples do you want? See why I didn't want to start this.
I still want to see the engine-side of one of these torque converters that need or utilize a pilot bushing/bearing.
SquareRoot
Cool. My old truck doesn't have one, but I learned something today.
Edit: I am boring. I only run what came as a factory option in my vehicles. A lot less headaches, and easier on the wallet. And the only foreign jobber is my 2007 FXT Forester. It is 5 speed with pilot bushing/bearing.
Turbo4whl,
I'm with Dingo. I learned something today.
They look just like any other torque converter. Look at that bushing pic I put up.It goes in the end of a chevrolet crankshaft and holds the pilot end of a regular old th350 torque converter when you have a motor plate. The bushing is just there to make sure the converter is centered.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
WTH? A bushing for a torque converter on a gen 1 chebby? Never hear of such a thing...
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Turbo4whl
Downingtown, PA
Wayne
Jimmy
I read this post before your edit. You were right all along. Should have left the sleeping dog lie.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
So basically the bushing, if needed, is only for centering on the crankshaft. For those that don't need a bushing, the nub that @Frankenchevy showed on the engine-side of his torque converter, goes in the hole where a manual transmission input shaft pilot bushing would go.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Okay, but that’s to adapt an LS engine to an early TC. Did a gen1 Chevy to a gen 1 TC get a bushing?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Not even that. Your TC snout should fit perfectly to the back of your crank with no bushing. The small hole for the pilot is about 1/2 of the diameter of the TC snout. I’m holding a MT pilot bushing up to a TC snout.
here’s a brand new gen 1 TC and a 327 crank. Identical measurement.
The pic I put up was th350 to gen 1 small block with a motor plate so that bushing makes up the difference so the center of the the th350 can center in the sbc crankshaft. Factory automatic sbc/th350 never had one to the best of my knowledge.If the end of the crank or the pilot on the converter are damaged a bushing is an option for repair.Its only to locate the converter in the crankshaft to keep the centerline.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
The pic I put up was th350 to gen 1 small block with a motor plate so that bushing makes up the difference so the center of the the th350 can center in the sbc crankshaft. Factory automatic sbc/th350 never had one to the best of my knowledge.If the end of the crank or the pilot on the converter are damaged a bushing is an option.
The third pic I see in your post says LS...
I must be looking at the wrong thing.
Yea I put one of those up too.
That little nub sticking out of your converter is called a pilot and it has to center in whatever crank you are using. So Cars with a motor plate need a bushing, different motor to different transmission combos sometimes need a bushing.Cars with damaged cranks or converters may have a bushing. And some manufacturers just bush them from the start .
SquareRoot
Good job @Frankenchevy !
Yes, there are bushings available but only in industrial applications or non-factory conversions made by the aftermarket. I still highly doubt bushings are used from the factory for engines and transmissions that were designed for production.
Jeep does
vince6868
