Parking Brake Light
tadslc
Birmingham, AL
Tad
350 Blueprint
The parking brake light on my dash has stopped working. Figure it might be the switch.
Been looking around, have no idea where this switch is located.
1981 C10
Thanks,
Tad
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
1981 C10
Thanks,
Tad
IIRC mine is right on the parking brake assembly, at the top. I think the circuit is tied into the combination valve wiring too.
WebMonkey
Missouri Ozarks
it should be on the parking brake lever/pedal mount.
at the top.
yes, the prop valve up front will illuminate the brake light constantly if it fails.
good luck
tadslc
Birmingham, AL
Tad
350 Blueprint
Thanks guys,
I thought I found it yesterday, looks like a slight b*tch to get to.
Is this switch available?
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
Here's a picture of a e brake pedal assembly not in a truck if that helps you. The switch is on the top right
Memaloose
Dolan Springs, AZ
Tony
It may be the lamp if it's original. Although that's not easy to access either.
tadslc
Birmingham, AL
Tad
350 Blueprint
Just to close out my post.
Turns out it was my bulb that had quit working. Replaced and it now works as it should.
Thanks again for the help, I think I dodged a bullet...
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
Always check the cheap stuff 1st
ESONE
