Parking brake cable mount for exhaust that exits to side in front of rear wheel? Pics?
Logbed
Europe
Caleb
C10 Silverado Longbed
I have this setup for parking brake in my '85 longbed. The cables hang quite low on the left side in front of the rear wheel so there is not good room for side exhaust exit. How have you solved this? Seems like a different mount in the frame could help lifting the cables higher, but would it create bad bends or other problems? Pictures appreciated.
Toad455
North Texas
Kevin
Sorry I don't have an answer but are these cables factory? The reason I ask is my 78 that I'm building has cables and they are going to hit the trans pan and cross member and what you have looks much better.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Different vintages route differently. Each has its +/- and aftermarket anything is a crap shoot these days. Fabricating a fix for this isn't too hard, just keep slack allowances in mind (sometimes you can adjust out some stuff) and keep all bends as wide as possible. You will see what you need to do. Sometimes those fat zip ties make it easy....
82jimmy
