One side sagging
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
I know lot of square body sagg on one side..mine is one inch too low driver side, well i know too that the driver,battry, brake system, fuel tank is on that side...my question is more how too fix that then why! :D
i got a belltech 5/7 drop
maybe just retapping the leaf set on the left side? :)
i'm gonna first mesuring diff to frame and in front between upper and lower A arm! ;)
thx for any solution
86Peter454
Missouri
C10 Scottsdale
springs get worn out over time.
one option is to just swap the sides of the springs left to right. this means when you are sitting in the truck it will level it out a bit.
or just get new springs all together.
mine sags as well but only the leafs in the back because the springs up front are brand new.
ive kicked around swapping the sides but its more work than i care to do lol.
jjester6000
Illinois
Jack
C1500
I don't know if you can tell, but my truck saggs to the passenger side.
The guy I bought it from was pretty fat, so I always joke that its in order to conpensate for his weight.
mine sags bad driver side. Also has the most sheet metal weight reduction and such, but the leafs in the rear are broken on 2 spots in the pack.
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
my front coil are brand new too..but my rear leaf is old thy for the input! ;)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
i think i'm gonna look and mesure those old leaf at back! thx :)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
buy a 1" rubber spacer for the front left coil! now it sit right! 1/4 inch in front and 0 even hight in back (before was 1-1/4 in front and 3/4 in rear) i'm happy! :D
79dentside
Kansas
Brandon
GMC Sierra Classic
Same issue here, but on the passenger side. Mine sits down around an inch lower on the passenger side with no air in the air shocks that I installed.
I unplugged the drivers side air shock and aired up only the passenger shock 2 nights ago and it leveled it out until I fix whatever is going on. I assumed it is a saggy leaf spring pack on that side.
For the time being it may help with weight distribution when feeding her the coal now that the back right corner stiffened up.... haha
ajd89
Central Michigan
andrew
Im glad your brought this up. My truck sags bad too! Passenger side is lower can see the difference in the overloads. Im wondering if someone put to much weight on one side and my spring is sprung.
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
since mine got now the good stance..my rear feel a bit to much low...so i buy back some OEM style rear shackle to get the right stance in back! man my ride confort is so much better...my vibration that i have to figure to (pinion angle setting) sime to be good! i never put again those drop shackle and now my truck ride so smouth! :D
Kim Burke
Northern IN
Kim
C1500
Please determine if the frame is bent or sagging springs is the culprit.
Sorry if this is confusing.
Measure:
Put truck on LEVEL pad.
Measure all four corners thru the center of the wheels to the bottom of the wheel well.
Determine the low corner front and rear.
* if either front or rear(side to side) is level, you’re screwed. The frame will likely not allow you to level up the truck.
Now, if the low side is the same (right or left) front and rear, the end with the most difference can be ‘adjusted’ to level up.
If rear is 1/2”-1” off, spring can be blocked to level up. Weight will shift to the opposite side front and level up the truck.
If front is off more than the rear, double check a ring in the coil didn’t break off the bottom. Take the outside ends loose on the sway bar and remeasure. I’ve seen them bent from running into something and they are stout enough the transfer weight if bent. If bar is straight, the front coil can have a spacer put between the rings but a C1500’s front‘s wire size makes it hard to do. I’ve put a rubber spacer under a sagging coil but temporary fix is all you’re getting. New coils and start over is the only sure thing.
phil97
