Old77's '98 ECSB 4x4
All those added miles !!! Duhhh !!!
Lol....the miles shown on that odometer is actually less than the original miles on the truck :naughty:
How far different are they? I think Retro knows how to take your old clock out of your current cluster and put in in the new donor cluster if you wanted to keep it accurate.
Yeah I'll have to hit him up. My truck actually has around 259k miles on it but with a 60k motor and fresh rebuilt trans
So it's only off by 102,000. No Biggie. :happy175: So does that mean you get take lots of **** back then since you haven't needed it yet when you roll back the odo???
Soo when are you going to get it up to 120 to make sure it works right. You know you have to.
:lol: I'm fairly sure this truck will not make it to 120 mph. The fastest I've had it so far is 90 and she was talkin back to me :roflbow:
bluex
Spartanburg SC
C15
There is a write up somewhere on Gmt400 on how to swap the odo...
Well still. You have to test the odo. And I have a feeling it won't do 120. (Unless someone played with the PROM chip) It should actually peter out at about 98-99mph IIRC.
TOADJA it could be done !!!
Cob don't be a *****, I've had an 18wheeler up to 115mph. Go put a chip in it, tune it a bit and use the new speedo, for what it designed for. :driver:
Lol....I'll be working on performance before long. Gotta get other projects tied up first before I move that direction :)
That's what I'm saying. Don't be a ***** !!! But, to protect the trans, GM OEM tune is max mph of 99 IIRC. Or is it 105 for the GMT400's and 99 for the GMT800's? I know my GMT800's petered out and NEVER hit 100mph without tuning. When my 2005 that ran reallll good for some reason, so I took it for a ride on the turnpike and it buried the speedo, I knew it had the chip worked over and prolly why it ran reallll good.
OK I'm going to let you in on a little secret.........What I do is I start rad ling off a bunch of car part that I want to my wife, see looks at me and says, "do you have to have it to make it run" I tell her YES, and she lets me go get it. I never mention that it is all the high dollar stuff. I don't consider it lying, because I do need the part!
:lol: I usually don't have an issue with the wife telling me I can't get something. I just like completing one aspect before starting on another or I won't get a thing done :)
And yes gmt800 had governor set at 98. Gmt400 was around 105 or maybe 110
J Knight
Baytown TX
82 Chevy
350ci
Must of been a slow truck.
Stewzer55
Ohio
Stew
R30
Hmm, my Trailblazer cuts out at 118 according to the manual. Its smooth at 100, I was running a little late for work one day.
Sent from my SPH-L710 using Tapatalk
F1r3truck
