MadOgre
- May 4, 2014
- NA
- NA
- NA
- NA
- NA
I think this is my problem, i use 1qt every 400 miles or so. 99% my intake leaks at the back. Oil sender etc are dry.
After 1500 miles my oil breather is dripping oil. I would like to fix it, but at the same time it is a tired old 305 so a used engine sounds better
Sent from my SCH-I605 using Tapatalk
My engine has the same amount of oil when it is first put in to the time I drain it for another oil change. Doesn't burn one drop. I have no leaks either. If you have a constant oil leak you could very well go through a quart a week. Leaks how ever do not explain oil in the air filter.
