NV4500 Swap - Clutch/Hydraulics Dilemma
mrgoodwrench
MN
mike
silverado
The master itself is indeed. The throw out is from the 05 nv4500 and has a similar fitting on it.
I seen the master on the 05 has that same roll pin line lock. Gotta be something out there to adapt to it, I’d think.
Id try the line for a late model chev 2500 pickup. Maybe something like this
Try searching the clutch line for a 1997 silverado k2500 just a guess but that looks like your master and the other end should fit the quick connector on a late model slave cylinder
https://www.partsgeek.com/catalog/1...utch/clutch_master_cylinder.html#immersedview
Sent from my SM-G970U using Tapatalk
Preston Tucker
Maine
Preston
How would one adapt to this style.
Do you have a link where i could get ths? i notice it has no N safety switch which is a big win.
eskimomann209
Modesto
Marcus
Yes i plan to, im running the internal slave bellhousing off the 2000 gmc and i want it to have enough fluid capicity
Cool. Sorry slow response been bouncing around. The master I posted is for an OBS 88-95ish ones.
Preston Tucker
Maine
Preston
and its abe to move enough fluid to correctly operate the 96 and up internal slaves?
eskimomann209
Modesto
Marcus
Oh ya.
Pretty common swap back and forth between the two styles. Internal and external slaves.
jlyon1006
