nv450+468c.i.= booom?
oreopenguin536
Reno Nv
Brett
307?
I had a 454 before and it seemed to get alright milage but then again it was a faaaaat a$$ tank… if i remember correctly it was something like 25 or 30 gal.
yevgenievich
Place
Name
Year
Model
Size
Square does loose 2mpg or so. It will really depend if you will have it carbed, tbi or vortec. I used to also own a 468 with 500+ hp ( had a blower on it) and it got somewhere between 3 and 6 mpg. Start with newer motor, and gear the truck correctly and will not need to change cam/heads. Will result in a reliable rig.
oreopenguin536
Reno Nv
Brett
307?
I want to go carb just because I wouldn't need to fuss with all the wiring or anything like that, and carbs are easy but as far as power adders efi would defiantly be better…. what about direct injection? I was thinking about turbo at maybe 20 lbs or boost or just all motor
crewcab higgy
chula vista
tim
r3500
Sm465
Sm420
The nv4500 will hold up to big tq fix the 5th gear problem and use a good clutch
I had one behind my cummins with a twin disc clutch 392hp and 811tq at the wheels held up fine.
also with adapters you can use the nv or gertag 5600
78silverado
