Nv3500 into an 86 k10, but not a normal swap.
bluex
Spartanburg SC
C15
Ah interesting.
I was wondering.
I just recently replaced the NV4500 in my 98 with one from a 95. I figured one for one swap, be easy. Nope.
95 is an external slave, 98 is an internal slave cylinder. Required me to get a new flywheel, clutch, and pressure plate.
Bellhousings don't swap either, different bolt pattern and center bore. What a pain.
Im gun shy now, lol
This also should have only required a pressure plate change to the older 95 an down style. The bellhousing is different because of the different bearing retainer styles between clutch fork an internal slave.
bluex
Spartanburg SC
C15
So I was just looking through Bluex's build thread and he mentions the need for "the correct pressure plate to work with the internal slave cylinder". Unfortunately, the link to his trans swap thread seems to be dead. Hopefully he will be able to let us know at some point.
It is kinda a good thread, maybe sticky worthy so it's easier to reference :shrug:
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
On that truck, the stock 98 flywheel was offset really far to the block.
The difference between a 98 and 95 flywheel was almost a half inch.
Between the flywheel, amd pressure plate change, it was about inch and an eighth thicker..
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
tryates3
