NP833 w OEM Hurst Shifter Problems
Big Ray
North Carolina
Ray
O.k., did some digging.
The shifter is a hurst, standard hurst rebuild kit should take care of it.
The mounting bracket is unique gm. There is a difference between 2wd and 4wd, so make sure you get those if you buy one of these units.
From what I have read, the 2wd units are aluminum case with 27 sine output shafts
The 4wd are iron case with 32 spline output shafts.
I got my trans in. I have a shifter rebuild kit on the way. Guy named Nick has an excellent tutorial on youtube for that, I forget what his channel is called. Old gear head, he's forgotten more than we'll ever know.
The shifter "fingers" the rods attach to are unique to gm units, so don't lose them.
When I get my shifter straightened out I'm going into the trans to see what it looks like. Mine won't go into reverse.
Mopar used the cast iron units behind their 426 hemis way back when, so strength is not an issue.
There was an overdrive set of gears available for the mopars also.
The Mopar units had a couple of different 1st gear ratios available.
I will post up any issues I encounter as I get mine ready for service.
All the information I posted is what I have gotten off the web. If I encounter anything contrary I will be sure to correct it.
Never rebuilt a 4 speed before, this will be fun.
and remember, this is all worth exactly what you paid for it! Lol
-Ray
Big Ray
North Carolina
Ray
My shift lever was bent over nearly 180* when I got it. It was the round stock slide in type.
Cool thing about Hurst shifters you can swap out the shift lever receiver (that's what it's called) to the bolt on type and use a standard square shift lever. I have one sitting on my nightstand.
I'm just waiting for the rebuild kit to come in...
Big Ray
North Carolina
Ray
Pics of my fancy new receiver...
Big Ray
North Carolina
Ray
Here's how my shifter looked when it came in. It was all still assembled when I got it. Notice the rectangular end.
The rectangular end slides into this type of receiver. It's shimmed tight and the lever has divits that mate with 2 nipples inside. Sill feels wiggly to me.
Another view. As I mentioned, it was all assembled when whatever caused the damage happened.
I had to straighten the mounting bracket, and I'll need to straighten the shift arms when I rebuild it.
Big Ray
North Carolina
Ray
FINALLY got my shifter rebuild kit in today. I'll start on it tomorrow....
Then I'll peek inside the trans...
2manysquares2care
