That was fast!
Hi any update on this?
I've changing from NP833 2wd to NP833 4wd, but don't have the different shifter. Any success making a mounting plate?
Oh that's my gold NP833 + 205 case earlier in the pics![]()
So now to answer your question. So you have 2 different A833's? A 2wd and a 4wd? So you're trying to convert the 2wd drive shifter to work on the 4wd tailshaft?
I think I asked over there if you got that worked with the NP205 and IIRC, you said you punted that project. So is that the case, or did you ever get the NP205 to properly mount to the 4x4 NP A833. From the best I could tell, you'd just have to put notch in the round transfer case adapter secton. Figured someone could use a gasket for a pattern and grind that out pretty easy. I'd love to use my A833 with an NP205 with fixed yoke and twin stick Tcase shifter.
Yes, I recognize your name @zetan. Welcome aboard buddy. Glad to have you here. You're the guy from P4x4 with the 3/4 van being converter to 4x4 IIRC. I thought of you when I seen the Ass Monkey episode where they took a square and converted a van to 4x4.
Just so you know, we're not pricks here like P4x4 guys can be. We're pretty loose around here, have very few rules and ALMOST anything goes, but the biggest thing and the quickest thing that will get anyone banned here is being a bully ass *****. Other than spammers, only been 2 people temporarily banned and it was for continual pissing matches, we worked through it and they're both members here, they just don't visit near as often. Other main rules to note, No nudity and no blood and guts. That's about it, so you may see some tasteless ******** from time to time and and some foul lingo here and there. Point is, don't be afraid to ask a question and get treated as if you're stupid or didn't find your answer in search. We've got some dupe threads here and usually the mods will handle merging those or consolidating threads if need be. We do get off topic here and there too. But, we do try to keep the under construction build threads on topic as much as possible as well as the tech "How To" write up threads.
The only nudity I'll be posting here is engine porn and bloody knuckles
I mostly post on dieselplace in the 6.2L forum, but 833 guys are hard to come by, so I'm here!
VEMCO V-Drive yeah I saw one in person on a late 70s van. Diffs on each front wheel.
Just like this. I'm not doing that!
http://www.curbsideclassic.com/blog/cc-outtake-1980-dana-v-drive-4wd-gmc-school-van-a-rarity-indeed/
I have a plasma cutter so I'll make something and report back![]()
Gotta admit though, the thought of a low slung 4x4 square would be pretty cool.
