NP208 stuck between gears/nuetral
Ifyasquintitsmint
Denver
I’ve been driving my NV4500/LS swap and recently tried to engage 4 low, couldn’t get the transfer case to move properly and now it’s stuck somewhere between gears or in neutral. I can’t force it up or down into 2H/4H.
What can I do to diagnose/fix my issue?
Is it the alignment? I recently redid my clutch and had to pop the shifter out to get to the transmission so I totally could’ve messed something up.
Edit: after reading I’m thinking I’ve misaligned the shifter. Going to look up a video on how to properly set it
MarineOne
Western New York
Most likely in neutral. Disconnect rods set everything to neutral including shifter and adjust properly
Strick
Dunn, NC
Harold
C20 Crew
Seems like the NP208 & NP241 have a snap ring on the tailshaft that will pop out of it's groove & this allows the entire cluster shaft to move back & forth in the case. You may check that.
HS
White Knight
