- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
Weren't most np205 rears fixed yoke?
I don't think so... I believe some of the dodge or ford ones were, and places like ORD sold a FYE kit for the Chevy units by sourcing the dodge output shaft. Apparently you can't get them anymore because the shafts aren't being produced anymore.
My 80 has a factory 205 and is the front Cardan flat plate like sirweesarunch's pic and a rear slip yoke with a one piece driveshaft.
You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
Based on those pics, it looks like someone has a weird mishmash of stuff on the front. Are those cast caps welded or stuck onto the universal joint cap on that cardan joint? I believe those caps would have originally attached to the flat plate that would have then bolted to the flat yoke on the front output of the 205. It would probably work(if you can remove the cap) to just remove them and use standard 1310 u-straps through that yoke. It would be the same straps on both sides then of the front driveshaft.
