Hottytoddy06
- Nov 24, 2014
- MS
- Matt
- K20
Hello all. I'm currently in the process of LS swapping the square with a 6.0 and 4l80e trans. The truck was originally SBC and SM465/NP205. I'm using the Advanced Adapters conversion kit # 50-0410 for my 2wd 4l80e swap with the NP205. I'm having a machine shop handle the tcase install kit/machining for the larger bearing. I know that I will have to cut the output shaft of the trans down, and that the crossmember will also have to be relocated.
This kit also states that "The 4WD linkage mounting bracket will need to be relocated further forward to allow for the added length of the new transmission." Has anyone ran into this issue? I was hoping to retain the original tcase shifter/linkage and was curious to know what others have done/seen with this setup. Thanks
