NP203, NP205, NP208 Differentiating Power to front and rear axles.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
BE careful on using old ubolts. Once they have been torgued and stretched they could break later on if being reused but thats just my opinion when it comes to holding my axles in i try not to cut corners
79K10
Sacramento,ca
Ryan
350/th350
good point, maybe ill get some new ubolts, cant be too expensive right?
but the steering link should be ok right? then ill only need longer brake hoses, i hope.
I know it's not a bad reccomendation, but I've not heard of anyone having an issue with used U bolts. But, I only know of a handful that have soooo who am I to say. If they aren't exepnsive and you have a source to get them from, then sure, new is always best.
smurph20
Brad
Same here HR never had any of my friends have them break but i never wanna be the first to know either lol
I need to find some myself. That Burb that I got the 4in front lift springs from, I also got the 3in blocks from the rear, but we torched the U bolts. I'll use those 3in block with the 4in front lift springs and should make my K10/1500 sit pretty close to level or at least closer to level since it sits higher in the rear now. Do you know of any good online source for U bolts only???
smurph20
Brad
DIY4X.com sells them im sure there are others that know a few too. I added those 4 leaves to my front end and used a three inch lift ubolt when i did it. Now its about n inch higher in the front compared to the rear.
79K10
Sacramento,ca
Ryan
350/th350
i scored today!! i helped some dude pull the diesel motor out of his 82 gmc long bed and he gave me the truck for $0! its pretty nice, 6 lug axels, 4 speed granny tranny, transfer case im not sure what it is, it doesnt look like a 203, 205 maybe? the shifter knob was gone so i couldnt tell you the pattern. i think its a k20 gmc sierra truck... this whole truck is at my brother house and i have the pink and everything! im gonna hack it up and use the cab and some of the interior trim
In 82, should be a NP205. SCORE. If it's 6 lug, just a K10.
79K10
Sacramento,ca
Ryan
350/th350
i thought it was a k10, but then i also thought i saw a k20 decal...?... ill have to take a better look at it and get some pics... i was in a rush to get it over to my brothers and then race home to get ready for work
A K10 is 6 lug axles. A K20 and K30 are 8 lug axles.
79K10
Sacramento,ca
Ryan
350/th350
here it is
Looks to be the NP205. Not only the NP205, but the good one with bolt on yoke. Higher spline count too. With that one, if you break your rear end, or rear drive shaft, you can shift to 4wd and still drive home on the front axle and shaft where as the slip yoke type, you'd lose all your fluid if you pulled a broken driveline or driveline to a broken rear end. The slip yoke also has less splines. Don't get me wrong, any NP205 is great, but this one is better than the other is all. So you got the best of the best in that one.
smurph20
Brad
Bro wish you lived closer I NEED that bed lol.
TDW1
