- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I've got one of those adapters and I can't sell it
Also, that np205 will not work behind a TH400, it will only work behind a 465 with a 10 spline output. You can swap a 27 spline input into the 205, then it will work behind a stubby output th350 or a 700r4 with a spacer. A 32 spline input won't fit into the case because it uses a larger bearing.
10-4. I remember you had that adapter. If you remember I hit you up and asked if you still had it that I know a guy who needed it. By the time I got back to him, he got one from buying a complete SM465 and adapter for $50 here locally off CL. But, yep, I know you have one. I do try to keep a memory of who has what.
