19gmc84
- Nov 12, 2013
- Virginia
- Norman
84 GMC...not sure if its original T Case or not...but I'm pretty sure from pictures I've seen...I have a NP203 T Case...manual locking hubs. I have no clue what the shift pattern is. From what I've read ...the shift pattern is as follows and could someone confirm...
4L
2L
N
2H
4H
Straight up and down. I understand the tranny has to be in N to go from any gear into 4L or 2L and I can be in D to go from 2H to 4H.
Problem is...I'm not sure what gear the shifter is actually in...with that said...how can figure out what gear the T Case is in without damaging anything...
So questions I have...
is the pattern above look right ?
How can I figure out what gear the T Case is in w/o damaging anything...can I simply lock hubs and then put tranny in N and shift T Case from gear to gear without harming anything and once I shift T Case to whatever gear...can I then put tranny is D and see if 4WD works?
And once in N...will shifter go side to side like a stick shift does? Will I be able to tell it's in N pretty easy?
4L
2L
N
2H
4H
