no power to anything in cab
curse
49002 portage mi
kyle
interesting. Another interesting thing is the wire that goes to the "s" terminal on the solenoid is also the power wire for my wipers! Lol.
GTP51
Melbourne Australia
Geoff
R10 Silverado half ton Stepside
Bottom of the fuse block in the cab is a fuse slot it is labelled “Command” re-place that fuse and you should be back up and running, had the same this with mine a few weeks ago, took me ages to find the problem.
Good luck
curse
49002 portage mi
kyle
Am I correct in thinking the wires at the junction block should always be hot? I'm doing more wire tracing
curse
49002 portage mi
kyle
I'm done, time for a new harness! Question...I have a nice interior harness out of a 78 and it has glass fuses. Any reason I shouldn't "go back" to glass fuses and order a 78 engine wiring harness?
curse
49002 portage mi
kyle
Got the new harness and installed it. Now everything seems to be operating like it should. I should have just replaced it a lot of headaches ago. Old versus new...
curse
49002 portage mi
kyle
I only have one question...does the bracket at the middle of the harness normally mount to the upper passenger trans to engine bolt?
rodfarm
