No power at all, zero lights, guage lights, or anything else. Any help wld be great.
87SQRBDY
Fayetteville, NC
Josh
R10
5.7l 350
I have a 1097 Chevrolet R10 Silverado with a 350 5.7 SBC and the starter went out, so I went to replace it with a Powermaster mini starter. Once I got it back together I tried starting the truck, but got no power at all.
I read through a lot of posts and didn't see one like this. My multimeter reads 12v at the battery, starter and alternator so I have no clue what to do. Oh, ignition switch is new too. At the end of my skill set and dreading having to take to a shop.
Any help or advice would be greatly appreciated.
gmbellew
Kansas city
glen
suburban 1500
I'd double check to make sure you connected the wires to the starter properly
75gmck25
Northern Virginia
Bruce
On the OEM starter there is a large lug where the positive battery cable is connected.
- On that same lug there is also a red wire (at least 10 gauge ) with a fusible link. This wire runs up behind the engine, through a protective metal tube, and then over to the power junction next to the master cylinder. This is the main power feed to the fuse panel.
- there is a second wire with fusible link (10 gauge? ) on the starter lug and this wire runs up behind the engine, along the top of the valve cover, and connects to the alternator BAT terminal. This is your charge wire.
I think you forgot to connect one of the smaller wires, or somehow created a short and it burned the fusible link.
tjw82c10
