Jason Lester
- Nov 15, 2018
- Cincinnati
- Jason
- C10
My truck sat in a garage for years. When I got it home I decided to unhook the fuel line to the pump and use an electric
Pump to empty the tank.
At about 2.5 gallons it acted like it was empty. No more fuel flowed from the tank
So I assumed it was empty. I filled it with 5 gallons of gas and put an inline filter in place. Cranked on the key and no fuel was pulled through the filter. I hooked up a boat tank and it pumped from it on the mechanical pump. At least some and ran ok. I tried the electric pump again and nothing from the tank.
Now my question is what is the likely cause of nothing coming through the tank/lines up to the pump. Some kind of blockage?
Can I blow Air back through it to clear anything in the lines without causing damage?
thoughts? Trying to avoid dropping the tank for now.
