No availability for 1/2 ton lower arms?
turbobuick1
Michigan
Tad
4.8L
Had anybody noticed that complete 3/4 and 1 ton lower control arms are readily available (and I mean $50-$70 via rockauto and eBay) but there is nothing out there for 1/2 ton trucks?
I have new ball joints and shafts/bushings ready to go, but if I can save some time and install something that’s ready to install and Powdercoated for under $100 a side........
DBarre
Rockport, Texas
Dustin
250c.i./4.1L
It looks like LMC has them but they don't look cheap.
animal
Lee
c10 silverado
350ish
They had them on ebay not long ago. Most were listed as JC Whitney so you might try there.
idahovette
Weiser Idaho
Perry
K20-K10
Good old JC Whitney . Bought a set of Flow tech long tubes for my truck a couple of months ago for $130 and free shipping, good deal!!
82c10stepside
Montoursville, Pennsylvania
Tim
About a year ago I ran into the same problem. At the time all of the ones listed on eBay said they fit C10 but they we're for C20 and C30. So I ended up buying C20/C30 ones. I pressed the ball joints out. Bought rings from Speedway that fit the C10 ball joints. I then welded them into the C20/C30 arms. Pressed in my C10 ball joints and wala problem solved. Doorman makes the C20/C30 arms. I wouldn't be surprised if they make the C10 arms for LMC. But LMC must have the exclusive rights to them.
82c10stepside
Tim
This is the ball joint sleeve I bought. The outside diameter is just a tad smaller than the C20/C30 ball joint.
RangRayy
Kansas City, Missouri
ryan
r10
LMC sells “remans” and for $300 you can rebuild them for a fraction of that. I ran into this six months ago when looking for my 1/2ton. Seemed difficult at the time to rebuild the stock ones but actually was not that bad of a job. Look at my build thread, near the bottom of page 24, I have pictures of how I did mine. Helps to have a press and a welder just in case the bushing casing gets frozen. Stripped mine down sandblasted and painted em and reassembled them.
LucHiscox98
